4x4
Old Jul 18, 2007 | 08:21 PM
windstar's Avatar
Default 4x4
on a 87 bronco11 4x4 if I change the rear diff ,do I need to change the front diff also?
I was told that it may not match.
Old Jul 19, 2007 | 08:45 AM
FordNutz's Avatar
Default RE: 4x4
As long as the gear ratios in them are the same it doesn't seem to me that it would make a difference.
Old Jul 19, 2007 | 10:50 AM
windstar's Avatar
Default RE: 4x4
Well this is the thing, the number on both rear diff is different(the # on the tag that is)
Old Aug 17, 2007 | 08:17 AM
Default RE: 4x4
Both front axles need to be the same ratio. If you have 3.73's in the front and rear and you change the rear to 4.10's, then the front also neeeds to be changed to 4.10's. What are the tag IDs?
Present axle:
Replacement axle:
country2
Apr 3, 2008 09:21 AM
nicknack24
Feb 5, 2008 10:53 PM
