Fluid change
Old Aug 5, 2007 | 07:53 PM
terry4's Avatar
Default Fluid change
Hi,new to this forum.Can some one tell me how to change the trans fluid in my 2005 freestar van.I look under it today could not locate the drain plug help me thanks[sm=hail.gif]
Old Aug 5, 2007 | 08:08 PM
Default RE: Fluid change
Sent you an email.
Old Aug 6, 2007 | 07:11 PM
Jakers's Avatar
There is no drainplug, you remove the ATF pan.
The pan gasket is reuseable after cleaning and making sure it is not damaged.
Install a new oil filter and clean the oil pan, also clean the magnet and place it in the same position in the oilpan, install the oilpan and fill the transmission with Mercon V fluid, about 6 quarts.
Warm up the engine and check the A/T fluid.
mikegigabyte
Feb 28, 2008 10:36 PM
elementx440
Jan 23, 2007 11:50 PM
tennesseesaturn
Nov 8, 2006 11:55 PM
mmahonzy
May 19, 2006 01:12 AM
mossimo817
May 10, 2006 05:47 PM
