View Poll Results: A poll
BATTERY
14.29%
ALTERNATOR
85.71%
Voters: 7. You may not vote on this poll
BATTERY OR ALTERNATOR?
Old May 25, 2005 | 04:45 AM
SW_601's Avatar
Default BATTERY OR ALTERNATOR?
2001 F-250 7.3L DIESEL - BATTERY OR ALTERNATOR?
When my battery warning light came on, I figured it was time to get new batteries. I drove the truck for one or two days. Then when I tried to start it the next morning nothing...Dead battery, warning light lit & battery gauge reading low.
I bought two new replacement batteries & installed them.
The battery warning light still remains lit, but the battery gauge reads normal.
I am able to start, drive, use the headlights & normal features of the electrical system.
When the truck RPM pings above 2000, the warning light goes out.
From what I understand an alternator does not increase voltage as the RPMs increase, so I should notice no difference.
I checked the serpentine belt, it appears to be snug & in good shape.
Any suggestions before I visit the repair shop?
Old May 27, 2005 | 02:23 AM
truckpuller's Avatar
Default RE: BATTERY OR ALTERNATOR?
Alternator probly has a bad or weak diode in it which will cause the light to come on.
Old May 27, 2005 | 01:26 PM
hockeyhitman69's Avatar
start with this you should have 12 volts at the altenator larger red battery wire and you should have 12 volts on one of the other wire in the connector with the key on if you do not it is in the wiring alot of times the wires corrode off right at the connectors seen a few times on trucks but much more common on focus hope it helpsand if it doesnt also seen when you remove regulator look at the brushes sometimes grooved befond repair.
Old May 27, 2005 | 01:41 PM
Patrick's Avatar
Administrator
go to a corporate shop, they will run a battery tester on it for free, and that will tell you whether it is the battery or alternator
Old May 27, 2005 | 11:34 PM
Just realized this is a double post [&:]
Was posted in the general tech section
Old May 28, 2005 | 04:20 PM
Patrick's Avatar
Administrator
hmmm..i just saw the yellow icon and clicked it.
Old Jun 18, 2006 | 06:31 PM
khyron6's Avatar
My 1991 350 van did the same thing, The belt looked good, Thought it was the alt. But the next day the belt came off.
guthrie1013@gmail.com
Jun 25, 2020 11:45 AM
bluzzer
Dec 13, 2018 08:56 AM
irinadel
Jul 30, 2011 09:46 AM
Dirty K
Dec 6, 2006 04:02 AM
SW_601
Jun 7, 2005 06:30 PM
