help need it bad
Old Aug 25, 2007 | 08:28 PM
greuelc's Avatar
Default help need it bad
I have a 1991 ford f-150 5.8l And i put a ten inch infinity powered sub woofer in it.I powered it with 4 ga. wire.andmy firstone 75 amp alternator went to hell.. So i put a 80 amp alternator it had good charging for a week and now it is not that great. what could the promlem be to cause it to draw that much power. And weaken the alternator.
Old Jan 4, 2008 | 02:58 AM
gixxer32404's Avatar
Default RE: help need it bad
may need those things "maybe called power packs" i know there's something people use in addition to battery and alternator,b/c they use so much juice.
Old Jul 18, 2008 | 11:59 PM
supra88's Avatar
Add a capacitor and check your gounds that small amplifier don't take that much power
Old Sep 27, 2008 | 03:07 PM
EXPOon22s's Avatar
well i have a ford expedition with two eclipse 15's with a 1000 one channel mono d-class amp which takes alot of power and it runs fine and have it just powered by the battery and alt. so you might have a loose ground wire and depends how you have the wires ran i wire cars all the time and you having a 5.8L you shouldnt be havin the problem my friend has the same one and its in a Volkswagon gulf so you should take it in
MrSauga
Sep 19, 2012 04:26 PM
rlpatte
Mar 31, 2012 08:45 PM
bignel71
Oct 14, 2008 11:28 PM
berbaby
Jan 13, 2007 08:28 PM
rispeed
Oct 29, 2005 06:09 PM
