stopped running
Old May 27, 2005 | 02:07 PM
95okexpolorer's Avatar
Default stopped running
My 95 Explorer just stopped running while traveling at 75 on the Hwy. It will not restart. checked the fuel pump relay and the intertia swithch too. need help. about to change the fuel filter out too.
Old May 27, 2005 | 05:41 PM
Default RE: stopped running
Check the codes, may have a sensor out causing problem i.e. the crankpostion sensor, or something. If it just cut off without a surging feel I don't think its a gas problem. Also just in case its not OHC engine, but if so check the time belt. good luck
Old May 27, 2005 | 11:41 PM
truckpuller's Avatar
Check to see if you got spark by putting and old spark plug in the wire and turning it over and see if there is spark besure the spark plug is grounded at the base of the plug
Good luck and lets us know
michaelc10
Apr 30, 2024 03:17 PM
hfb1957
Aug 20, 2010 01:43 PM
dcove
Aug 18, 2010 06:13 PM
graven57
Jun 4, 2007 02:42 PM
tanklord
Apr 1, 2007 07:39 PM
