Alternator, anti theft problem
Old Sep 1, 2007 | 11:57 AM
rottensx2's Avatar
Default Alternator, anti theft problem
Hello,
I have a 2001 excursion that is on its 3rdaltenatorsince late May 2007. We haven't been able to track down what is causing them to go bad. It has a new starter, new batteries and new battery cables as well. The only thing odd going on that I am aware of is the theft light is blinking all night long. I can't figure out how to get that to stop either. I don't know if this is related or its just some electrical short. Any suggestions?
Old Oct 29, 2007 | 12:43 AM
liljoey007's Avatar
Default RE: Alternator, anti theft problem
hey the teft light is supposed to blink.the alternators you maybe putting in could be faulty from the start are they doing a voltage test before and after the alternator is put in to assure a good alt is installed.....you could have a faulty ignition switch....also check the plug going to the alt.you also could have one bad cell in the battery causing the alt to put out max power all the time to make up for the bad cell.you could also have a bad starter needing more than usual power to staart the vehicle hence alt recharging battery...a full starting,charging,and battery system check will verify.......
neford
Sep 21, 2018 03:44 AM
usah64
Oct 23, 2010 10:00 AM
jerridianeday66
Jun 25, 2008 01:24 PM
justingarner2
Sep 24, 2007 01:23 PM
Heynow
May 1, 2005 03:54 PM
