Help with 92 Mercury sable OBD-1
Old Sep 4, 2007 | 11:10 PM
emr454's Avatar
Default Help with 92 Mercury sable OBD-1
Hi all, this is my first post and I hope someone can help me. My sister in law has a 92 Sable with the check engine light on. I was searching around the net tyring to find a way to retreive the trouble codes from the EEC diagnostic connector. I read that you have to ground 2 pins together and hook a test light up and count tha number of flashes on the test light. Is this true? If so, what two pins on the connector have to be grounded? There are 5 on the connector and there is another wire with a small plastic connector in the same wire bundle as the EEC connector. If this isnt the right way, does anyone know how to get the codes out of an OBD-1 system? Any and all help is appreciated. Thank you!
Eric
Old Sep 5, 2007 | 12:01 AM
Default RE: Help with 92 Mercury sable OBD-1
Hope this helps..
[IMG]local://upfiles/6756/54F27A393EE24D54BCD2DCD31A9707BD.gif[/IMG]
Old Sep 5, 2007 | 07:13 AM
emr454's Avatar
Thanks! That makes much more sense. Her car does have the MIL light so it will be a piece of cake. Many thanks!
Eric
jlank
Jan 12, 2013 01:19 PM
Chelsea Erika Callahan
Jan 6, 2013 12:32 PM
david2007
May 17, 2007 09:08 AM
mjm4310
Jan 16, 2006 11:37 PM
jlank
Apr 8, 2005 12:23 PM
