91 Ranger - Trouble shifting (Manual)
Old May 30, 2005 | 12:48 AM
glorib's Avatar
Default 91 Ranger - Trouble shifting (Manual)
I have trouble shifting mostly into reverse. 1st and 2nd are tough to shift now and then but not always. I hear a noise when I push the clutch in. Any ideas?
Old May 30, 2005 | 02:02 AM
Tempestv's Avatar
Default RE: 91 Ranger - Trouble shifting (Manual)
Had this exact same problem on my Saab- started with trouble getting into reverse, then started effecting other gears. I looked around and found a leak on the clutch line. I just cut the line on each side of the leak and rebent the line so that it followed a shorter path so that even with six inches missing, I was able to bring the two ends together and flair the ends so that I could use a brass fitting to join them. then I bled the system untill I had a bit of pedel.
Here is a good site for that-http://www.findarticles.com/p/articles/mi_qa3828/is_200412/ai_n9466063
Old May 31, 2005 | 12:51 AM
truckpuller's Avatar
Does your clutch pedal have alot of free travel in it??
May just be time for a new clutch and if you keep driving it like it is you will damage the syncronizer rings inside the transmision and wind up having to have it rebuilt also.
Old Jun 1, 2005 | 01:22 AM
skippy440's Avatar
I agree with truckpuller. I would look at the clutch and gears in the manual tranny first. You might also want to
check the fluid in the tranny.
Old Jun 4, 2005 | 12:57 AM
glorib's Avatar
I took tempestv's advise and checked for a leak. It was bone dry, but couldn't find a leak. Added brakefluid, got the air bubbles out, and now I don't have all that travel in the clutch when I press down anymore. so that's good. But still have trouble shifting. The tranny fluid is fine. Starting to wonder what else. It does make a sound like a pump is going bad or something when I push the clutch all the way in. Is there some kind of hydrolic clutch deal going on?
Old Jun 4, 2005 | 03:20 AM
Tempestv's Avatar
TO bad it wasn't something simple like my little problem- I guess I got off lucky. Could you describe this sound better? Is it only when you push in the clutch? High or Low pitch? I have never heard of a powered pump on a clutch, but I guess anything is possable.
Old Jun 4, 2005 | 06:23 AM
glorib's Avatar
It only makes the sound when I put the clutch all the way to the floor. It's not loud, just a faint rattling type sound I guess. It reminds me of a motor that's pumping fluid only the pump has run out of fluid....I don't know. I'm wondering if the master cylinder is going out. Maybe that's what it sounds like. I just remembered that it used to make a popping sound when I pushed the clutch in, and it doesn't do that anymore for some reason. It stopped popping for no reason at all, like maybe it finally broke whatever it was.
Old Nov 16, 2005 | 10:56 PM
LIMEGREENRANGER's Avatar
I KNOW I WAS HAVING SOME WHAT THE SAME PROBLEM DOES THE CLUTCH SQUEEK WHEN ITS PRESSED IN AND LET GO
chris_d
May 30, 2013 09:51 AM
Devon Stickrod
Aug 24, 2012 08:06 PM
marrigoround
Aug 30, 2011 10:45 PM
SYT
Aug 18, 2008 07:36 PM
cristieluvsherford
Jan 19, 2008 12:21 PM
