Passive Shoulder Belt Broken
Old May 31, 2005 | 12:19 PM
95EscortinOH's Avatar
Default Passive Shoulder Belt Broken
Hi,
Any advice on where to start looking for the cause of the passive shoulder belt retractor not working or on where I can find a link?
It's stuck in the fully upright position and won't move to allow you to get out of the car. It's a real pain to slip in & out of. I think it may be a limit switch or something but don't know where to look for the sensor or what to check for once I find it.
I guess I need to know which sensor is supposed to supply a signal at what times to make this work.
My local shop want anywhere from about 180-450+ to diagnose/repair this. Please Help!!!
Thanks in advance!
Old May 31, 2005 | 03:07 PM
Tempestv's Avatar
Default RE: Passive Shoulder Belt Broken
there is a switch in the door frame that controls the interior light. my guess is that this same switch also runs the seatbelts and the emergency chimes to tell you to close your door. if this is the case, and that switch is bad, the car will not know when the door is open, and consiquently, when to move the seatbelt forward. Try this- set the dome light so that it turns on when the door is opened. when only the drivers door is open, is the light on? if it is not, your door switch is probabilly bad. I know that they go out quite frequently. You may be able to order the switch from NAPA or even find one in a junk yard, although you should test a junkyard switch with a multimeter, and it is anyone's guess how long it will last.
Old Jun 6, 2005 | 09:02 PM
The door switch was it!
Thanks for the advice!
Old Jun 7, 2005 | 03:36 AM
Tempestv's Avatar
How much did it cost?
Old Jun 7, 2005 | 12:03 PM
It was $3.00 at the local salvage yard.
1969galaxie
Sep 26, 2012 08:41 PM
rebelmom
May 21, 2008 12:07 PM
tsi18psi
Sep 2, 2007 01:51 AM
burlapsac
Aug 24, 2005 02:18 AM
alotz
Feb 22, 2005 03:05 PM
