FUEL PUMPS ON BRONCO 2
Old Sep 25, 2007 | 08:39 AM
broncoII84's Avatar
Default FUEL PUMPS ON BRONCO 2
I think my fuel pump is bad in my bronco. I have heard there are two, which one is it most likely to be. In tank or on the frame rail.
Old Feb 13, 2008 | 07:55 PM
Superfuss's Avatar
Default RE: FUEL PUMPS ON BRONCO 2
I've got an 86 and an 87. The 84s are about the same. The pump in the tank is a high presere (sender )and the one on the fram is a low presere( return ).If I had to pick one I would say the one in the tank. Turn the key toon but, do not start the truck, and thenlisten. If you hear a hum, that should bethe one in the tank.That will mean it's working and the problums somewhere eltes.
Old Apr 3, 2008 | 09:41 AM
robin rea's Avatar
There is only one pump on the 84 Bronco 2, the way that I know this is through personal experience of making a fuel pump change... Good luck, if you are going to change it alone, it is down under things, and can be a bear to get to.
drjoe
Sep 19, 2010 04:06 AM
danford1
Jan 27, 2010 08:39 PM
drockstar
Sep 21, 2009 09:30 PM
colli360
Jan 26, 2008 10:19 AM
Flattire Fred
Mar 28, 2007 02:37 AM
