Engine & Internal Lounge Chat about beefing up your insides here.
Gets Hot Wont Start
Old 08-20-2005 | 04:04 AM
79Chero's Avatar
Default Gets Hot Wont Start
I Have A 79 Ranchero With A 351m when its cold it starts right up like it supposed to. but if u drive it for a good 10-15 minutes then cut it off it will not start right back up.Does Anybody know what could be wrong i changed the ignition box and got another carb. im pretty sure its not vapor lock because it has plenty fuel i can hear it squirting out when i pump it under the hood.
Old 08-20-2005 | 04:21 AM
Ramrod48's Avatar
Default RE: Gets Hot Wont Start
Could be your coil , gets hot an breaks down, Also , the pickup in the dist , is another possibly. On your Ign module , did you clean the connections real good ?,,, Also on these ole girls they were bad about the wire insluation shrinking back , leaving bare wires touching , Causeing a temp short .,, On the dist. theres 3 wires I think at the base . pull that connecter apart an look at the terminals , the black wire is the ground , they were famous for going bad... http://www.autozone.com/servlet/UiBr...ginRepairGuide
try this web site just enter the ifo , will give you complete troubleshooting specs, an how to do it . you can print it out an take to car . .. Oh an welcome to the Board !!!
Old 08-20-2005 | 04:36 AM
79Chero's Avatar
it did it about 30mins ago so i swapped the coil for a new one still had nothing so im going to just keep gping piece by piece.I'm 17 but i have a mopar the ford belongs to my dad.
Old 08-20-2005 | 04:41 AM
Ramrod48's Avatar
You said your sure its getting fuel. when it dont want to start , Pull a plug wire off an see if your getting spark ?? , Also dont rule out your fuel tank cap till you have checked it ,, I have seen them build up a vacuum, so bad that when you pulled off the cap , You could hear the tank expand ,, An 10-15 minutes would be about rite for the vacuum to bleed off by its self.,, These ole dura spark 2 ign. system are pretty easy to work on. Let us know what you find ..
Old 08-20-2005 | 04:50 AM
79Chero's Avatar
i checked it for spark the other day from the plug wire's and i checked from the coil i got nothing at all.but still ran after it cooled out
Old 08-20-2005 | 11:12 AM
Ramrod48's Avatar
Ok, good , is the ign module (box) as you called it new ???, I think were back to the pick-up in the dist being faulty , Thats my story !!!!!!!
Old 08-20-2005 | 03:59 PM
79Chero's Avatar
yes i changed the module, im gonna go pick up another distributor today because mines pretty old anyway it has sort of a grinding sound coming from it. so ill just replace the whole thing.
j1004ss
07-15-2015 03:05 PM
a_cmc_2b
04-09-2008 11:56 PM
xxpaperpusherxx
08-10-2005 04:08 PM
jdog
08-09-2005 02:06 PM
