68-69 Torino fan...
Old 02-15-2011 | 02:40 PM
msz40's Avatar
Default 68-69 Torino fan...
Hello to all. 68 Torino owner here. Waiting for the ice to melt here in the Northeast.
Old 02-15-2011 | 05:26 PM
Bluethunder1959's Avatar
Default Can you post a few pics?
Hello Mike,
From your post, do you still have the 1968 Torino S code? I have been having a real hard time getting information and stock pics of 1968/69 S code Torinos and Rancheros. I own a 69 Ranchero GT with an S code 390 and C6. Problem is, all the pics I usually see of cars so equipped, have been modified. I would like to check out some in depth pics of a totally stock engine bay. I don't suppose yours is stock?
Old 02-16-2011 | 11:51 AM
msz40's Avatar
What area would you like the pics from? It is how I bought it, except I installed factory steel valve covers in place of the aftermarket chrome ones and i added the air cleaner...i have a fan shroud to install yet and a new water pump spacer. Mine has the clutch fan which is prob not stock and too close to the radiator.
Mike
Old 02-24-2011 | 12:24 PM
A few pics of the firewall, both sides of the engine bay and a front shot would be nice. What did you do with the original air cleaner on yours?
Old 02-25-2011 | 10:27 AM
msz40's Avatar
Default console advice
I removed the chrome aftermarket air cleaner and installed one I got from a friend. It might be from a 429, I did not compare it to a stock 390 4bbl one.
These are all I have..prob not much detail. I did not compare mine to any other known stock engine compartments, although the machine shop told me the distributor is off a tooth because the vac advance should point towards 7 o'clock instead of 5. It runs like a raped ape so I'll prob leave it alone.
Looking for a new console. I've seen new fiberglass ones and new abs ones in online catalogs, anyone have any input? Mine is pretty much not repairbale by a novice anyway.
Thanks,
Mike
Attached Thumbnails 68-69 Torino fan...-006.jpg   68-69 Torino fan...-009.jpg   68-69 Torino fan...-016.jpg
Old 08-28-2012 | 09:39 AM
Tims 69 gtconvertible's Avatar
Hi Everyone,
I am new to the forum, and looking for any pictures or info on fan radiator, crank pulley clearance for 69 torino gt 390 engine.
I restoring the car, and currently almost ready to fire up the newly rebuilt engine. When I bought the car a few years ago it was complete except for radiator and fan (becuase it was in a front end accident). So now I have engine and rediator installed with a 7 blade flex fan. Without a spacer the fan hits the crank pulley. If I move it out 1 1/2" it is 1/2" from the pulley, but is 3/4" from rad. My concern is the flex fan may hit rad. and / or pulley.
Any picture of fan/rad/pulley would be appreciated, and information on fan/fan profile/fan dimensions, such as : does fan blades protrude from the mounting surface and by how much?
Thanks for your help.
Old 08-28-2012 | 01:41 PM
grindman's Avatar
the only way for your fan to hit the radiator is if your spacer is too big or your flex fan is backwards
RedHot30
03-08-2007 05:16 PM
daylynn
03-06-2007 09:38 PM
acidpad
03-04-2007 06:19 PM
BeastOfBurdon
07-05-2006 07:18 PM
RedHot30
03-21-2006 11:12 PM
