tranny swap
It probably would fit, assuming that is a Ford T10. Early Toploader would probably fit as well. Does that Jegs bellhousing have 5 bolt motor end pattern, or is the 289 motor a 1965 or newer with 6 bolt motor end pattern for bellhousing.
tranny swap
great, now i got to get down on the floor again. will let you know if i make it back up.
