Transmission Swap on a '57 Fairlane
I have a '57 Fairlane that has a 1958 352FE in it with a 1958 Fordomatic transmission. I would like to swap the Fordomatic out and go with a floor shift manual transmission. What tranny could I use in this application?
Thanks.
Thanks.
1958 1964 FORD 352 390 406 427 3 & 4 SPEED MANUAL TRANSMISSION BELL HOUSING | eBay
A doner car with manual transmission compatable to your yr. make, model car could be used to install the clutch pedal assembly. Aftermarket clutch pedal assemblies are also available. Here are a couple of links to give you an idea...
Wilwood Brake/Clutch Pedal Assemblies - SummitRacing.com
Wilwood Brake & Clutch Pedal Assemblies - JEGS
Ford used the BorgWarner T-10 manual transmission between about 1956 to 1965. They came available with floor shifters. To bolt the T-10 to your 352FE you may need...
Thanks for the help.
Anthonycb66
08-18-2012 09:21 PM
danowens
11-14-2006 11:59 AM
