1984 Bronco II- Turn signals not working
Hello,
Our turn signals don't work. Don't know what's wrong. We replaced the fuses even though they were fine to begin with, the flasher, and even the switch itself. The hazards, headlights, and brake lights work even though the left side turns dim when the headlights are on. What could be wrong? Please help! We want to drive it!!!
OH yea, the heater stopped working but once in a while, at random times it does? This could be a separate problem i'm sure. Our bronco has a long way to recovery.
If there's anyone who lives in Washington state who know how to work on our bronco, we want some extensive mechanical work done. (brakes, maybe new motor) Please respond thank yoU!
Simple thing to check would be to clean the ground connections from the battery ground cable and then from there to all the sheet metal.The lights all have a wire that connects to a ground connection and if the ground connection is poor the lights won't work properly.
samchristine
10-16-2021 11:05 PM
Durr
10-08-2011 10:02 PM
Screenwriter
01-06-2010 09:59 AM
