Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
302 to 460 swap
Old 01-12-2011 | 09:03 PM
skippy1980's Avatar
Default 302 to 460 swap
Have an 88 Bronco with a 302. Been offered a 460 to rebuild and drop in it. Concerns i have: Will it fit? Is my 4sp AOD trans man enough to handle it? Over all work worth it? If it makes any difference 460 is out of 89 F350.
Old 02-06-2011 | 01:12 PM
hile57's Avatar
get any real feedback other than the moron with the shoe reply...would like to drop a 460 in a 91 bronco that has a 302
Old 02-08-2011 | 09:27 AM
Bullitt94's Avatar
Well, I'm pretty sure you aren't looking at a straight swap here. Blocks are pretty different so mounting points are going to have to be modified. Not sure if your tranny is a direct fit, either. If it fits the tranny will handle it for a while, but most likely will wear out especially if you plan to do more than drive back and forth to work.
However, a 460 would kick a$$ in that Bronco!
Old 10-30-2018 | 08:08 PM
RedneckPackrat's Avatar
I realize the post is 7 years old, so one of three things has happened.... either it's still got the 351 in it, or you did it and found out what Dad and I learned, or you got shed of the whole thing
We did this to an 86 F150, put a 460 in it. Needed to basically swap out the suspension and motor mounting ears (towers) from an F250 to get it to line up right. Once we did that, it was a straight drop-in procedure. Oh, and that damn thing would SCREAM, too!
That one had a C6 in it, no idea of whether the A4OD will handle a 460.
Bill
78lynchf250
03-24-2015 08:00 PM
Monster_Magnet
07-31-2009 10:26 PM
dirigo
07-25-2007 11:21 AM
mustang50racers
01-16-2007 01:55 AM
