89 Bronco II power windows
Hello,
My Bronco II has a problem with both windows. They don't work. The passenger window was working until recently. We replaced the motors and the driver side actually worked for about 1/16th of an inch. So it's electrical or the buttons don't work, correct? Anyone else had this problem and if so, where is the best place to look for electrical problem?
Thanks
Thanks
RE: 89 Bronco II power windows
[sm=welcomesign.gif]I would start at the switch.[hr]Pull it out and check it for power.[hr]Then hit the switch and check the other side for power.[hr]If you have power at the switch then go into the door and check for power at the motor with the switch pressed.[hr]No power at all check the fuse or circut breaker.
Alex
12-04-2007 07:40 PM
