95 Bronco rear glass removal
1995 Bronco with electric rear window. Window is in the down position. Getting 12 V to the plug going into the rear window. Opened rear door removed access panel, closed latches cannot rise glass. Used a 1/8 flat bar with a 90 degree bend and was able to apply considerable amount of pressure but glass will not move. Any hints?
i have a 91 bronco...and had similiar problem....i had to replace the whole arm assembly motor and all. its not a hard task but had to shut door and do all work inside back area and upside down. you will need to be flexible. my local parts store had everything in stock so it was easy fix
