Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Engine Swap
Old 05-26-2010 | 06:15 PM
d.smith's Avatar
Default Engine Swap
I have searched around and think it may be easier to just ask. I have a 1994 Ford Bronco with 302. I also own a 93 Ford E-van with 351w that will be my donor. Engine swap is not an issue but I would like to know what changes I need to make on the 351 before I attempt to drop it in. I think the oil pan needs changed(but uncertain) Maybe the mounts? Both are efi system so the harness should be same? Does the ecu need to be changed also?
bmwrocks03
04-21-2008 10:29 PM
matt95ssei
04-05-2008 03:15 PM
F 150 Bama
08-20-2005 03:06 AM
92FlareSide
07-01-2005 03:30 PM
fordmann67
05-08-2005 10:22 PM
