Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Engine swap Bronco
Old 10-12-2006 | 11:41 AM
Adkrpd's Avatar
Default Engine swap Bronco
Hello, I need some advice / instruction on changing a 5.0 engine from a 1989 Bronco to a 1995 Bronco. They both have the same size engine, but I was wondering what kind of problems I would run into.( such as electrical connectors ). I appreciate any help, Thanks Rick D.
Old 10-12-2006 | 12:12 PM
94 4x4 ranger's Avatar
Default RE: Engine swap Bronco
[sm=welcomesign.gif][hr]As far as the electrical connectors you should reuse the old intake manifold this way all your connectors will be the same.[hr]For the engine removal.[hr]You will have to remove the bell housing bolts,motor mount bolt's,tourqe converter bolts to flywheel,disconnect all wire's and hose's to engine,remove radiator,disconnect exaust,and the a/c if you have it.Every thing must be disconnected from the engine in case i missed somthing. and get a engine hoist and remove the engine.[hr]To install do the above in reverse.
Old 10-12-2006 | 12:16 PM
Adkrpd's Avatar
94 4x4 ranger, Thank you, That's the exact info. I was looking for !! Take Care
Old 10-12-2006 | 12:28 PM
No problem,You may want to buy the book for your truck for more detailed info.And the intake must be tourqed in a special way with a tourqe wrench.
84bronco2
07-11-2011 07:54 PM
Adill56
07-10-2011 09:26 PM
charlie55
11-29-2009 12:12 PM
noonrock
01-13-2009 10:00 AM
Adkrpd
10-12-2006 12:28 PM
