Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
FUEL PUMPS ON BRONCO 2
Old 09-25-2007 | 09:39 AM
broncoII84's Avatar
Default FUEL PUMPS ON BRONCO 2
I think my fuel pump is bad in my bronco. I have heard there are two, which one is it most likely to be. In tank or on the frame rail.
Old 02-13-2008 | 08:55 PM
Superfuss's Avatar
Default RE: FUEL PUMPS ON BRONCO 2
I've got an 86 and an 87. The 84s are about the same. The pump in the tank is a high presere (sender )and the one on the fram is a low presere( return ).If I had to pick one I would say the one in the tank. Turn the key toon but, do not start the truck, and thenlisten. If you hear a hum, that should bethe one in the tank.That will mean it's working and the problums somewhere eltes.
Old 04-03-2008 | 10:41 AM
robin rea's Avatar
There is only one pump on the 84 Bronco 2, the way that I know this is through personal experience of making a fuel pump change... Good luck, if you are going to change it alone, it is down under things, and can be a bear to get to.
drjoe
09-19-2010 05:06 AM
danford1
01-27-2010 09:39 PM
drockstar
09-21-2009 10:30 PM
colli360
01-26-2008 11:19 AM
Flattire Fred
03-28-2007 03:37 AM
