Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Push button 4x4 on 90 bronco
Old 02-13-2006 | 10:41 PM
slammr316's Avatar
Default Push button 4x4 on 90 bronco
Don't you just hate when you get 17in of snow and your 4x4 don't work? I push the button and hear some kind of solenoid clicking but it just wont engage. any suggestions? Please reply.
Old 12-16-2007 | 11:01 AM
cpubuilder's Avatar
Default RE: Push button 4x4 on 90 bronco
I don't know why no one replied to you, this is probably fixed or long gone by now, but I have the same problem. If the solenoid is engaging at the transfer case (easiest way to tell is the noise it makes or see that the front shaft is turning, then it is you hubs. Mine is the hubs, trying to look at manual ones or something.
Old 11-04-2008 | 07:42 PM
bryanb70's Avatar
I have a 90 bronco push button 4x4. It does the same thing, but worse in the cold. I believe it's the motor not a solenoid. Still haven't changed mine, but if i keep trying it finally it works.
Old 01-11-2009 | 03:41 AM
goinstrong's Avatar
The motor is usually more prone to go. Hubsmight notlock right without it?
55blue
07-03-2013 08:33 AM
sludgemonger
01-12-2011 11:42 PM
Thebeast
02-13-2008 08:41 PM
rangerr731
11-23-2006 01:49 PM
RayeAlmighty
10-02-2005 07:20 PM
