2014 Cmax Energi transmission replacement the light problems
Greetings. Thanks in advance for ANY and all insight you folks are willing to provide. I just had the transmission replaced on my 2014 Ford Cmax Energi. Actually, I just picked it up from the shop today. It would seem that NOW my driver's side headlight (low beam AND high beam) and signal light are not working. It seems unlikely that all 3 bulbs would blow at the same time. Is it possible that this is somehow related to something that the repair folks did or didn't do? (According to the service record, they had to remove a lot of bits and pieces before they could install the transmission. )
Last edited by SherryS; 10-09-2024 at 07:42 PM. Reason: Actually wanted to change "the" in title to "then"... but couldn't. Can you please?
