96 ford contour rearend on the loose
[]my rearend on my car is like i have no control it like hit a bump and it sways to the left on a lil slick roads cant drive past 30 or my rearend has no control its like im driving but rear wants the other way like im pulling a hay wagon HELP HELP HELP
[IMG]local://upfiles/14791/2367426C5E5949609A003AB1F774152C.jpg[/IMG]
RE: 96 ford contour rearend on the loose
You might have someone check the rear suspension on this one. I believe it has an adjustable rear toe and you may have some loose or worn parts in the suspension. check for loose bolts and tie rod, also jack it up and make sure the wheel bearings are alright. They are a sealed bearing and can start coming apart without a lot of noise.
rebar
05-12-2013 05:11 PM
