headlights
headlights
ok i just replaced buth bulbs and the fog light bulbs too all work too just the headlights sim really dim the lenses are clean but just doesnt seem like getting alot of power to them any1 know why? like a relay or something?
RE: headlights
Are the lenses clear or hazy? The lenses deteriorate over time, causing the lights to be dim. But you can't see too good into the light if this is the case. Had that problelm on a '98. You can 'clean' the lenses or buy new ones.
RE: headlights
hi i have a 1998 contour and i have the same prob my brights are good and dims suck but when i get on the gas it dims bad does yours do that too?i was thinking its the ALT going bad i had this on my 89 prob it was at 12.5 on charge and i was just looking on here my self for a mod gone wrong too and some others i will post anything i find out to you and if you could same for me thanks
RE: headlights
ORIGINAL: jlfrnce
The light dimming thing is a TSB that is for Cougars, but the fix they give fixes this problem in Contours too. Too bad we are not part of this recall. (I was just reading this one) Here it is in part......
TSB00-25-06
Article No. 00-25-6
• CHARGING SYSTEM—HEADLAMPS, INSTRUMENT CLUSTER, RADIO OR INTERIOR LIGHTS FLICKER WHEN COLD—VEHICLES EQUIPPED WITH 2.5L ENGINE ONLY
• ELECTRICAL—HEADLAMPS, INSTRUMENT CLUSTER, RADIO OR INTERIOR LIGHTS FLICKER WHEN COLD—VEHICLES EQUIPPED WITH 2.5L ENGINE ONLY
MERCURY: 1999-2000 COUGAR
ISSUE
Some vehicles equipped with a V6 engine may exhibit a flickering condition of the headlamp, instrument cluster, radio, and interior ights during engine start-up and may continue during the first several minutes of engine idle. After several minutes, the flickering will subside but may not completely diminish. This may be caused by excessive electrical resistance in the battery voltage sensing circuit. Vehicle operation is not affected by this condition.
ACTION
Reroute the battery sense line from the engine cable, untape and remove. compartment power distribution box to the B+ terminal on the alternator. Refer to the following Service Procedure for details.
