Help with My Contour!!!
My 1998 Ford COntour will start but wont shift out of park. Changed out the TCC Solenoid, Shift Solenoid, and the Throttle Solenoid in the trans oil pan. Put a new Stop Lamp Switch/brake switch. Will not shift at all. What else could cause this problem and how can i fix it?
Contour Gas gauge Not working.
ok I have a 2000 ford contour 2.5 v6. i bought the car a Month ago replace the fuel pump because of Low fuel pressure, i notice the Fuel gauge hasn't moved. I unplugged the plug from the fuel pump an it didnt move at all, dont know what to check now. Please Help. Thanks
