1955 Crown Vic starting problems
Old 10-13-2012 | 08:00 PM
boz's Avatar
boz
Default 1955 Crown Vic starting problems
Just bought this older restored car. Car runs great (272), does not overheat but when I shut it off and let it sit for about 10 minutes, it will not start until engine cools down to about 140 degrees or lower. I insulated the fuel line, ventilated the fuel tank, and put in new fuel filter. Need help, suggestions. At a loss...
Old 10-18-2012 | 05:15 PM
jdmeaux's Avatar
Default heatsoak
Try getting a heat shield for the starter. GM had problems with heatsoak of the starters for years, and finally decided to put a heatshield over them to keep some of the heat from the exhaust manifolds. I even had made me one out of a piece of scrap aluminum, drilled to fit the bolt pattern of the starter head and went part-way around the starter.
Martin001
12-22-2015 04:16 PM
gnorton52
10-03-2010 08:57 PM
royleexx
01-26-2009 03:15 AM
gcsmial
01-04-2009 01:53 AM
Deno
12-06-2007 02:52 PM
