1997 p71 questions
Old 09-16-2012 | 10:27 PM
XXX Racing's Avatar
Default 1997 p71 questions
We bought this car to run circle track races. When we got it someone had cut the exhaust off up to the manifolds. This car sounds like it's not running on 8 cylinders and has an intermittent pop out of the exhaust. Its had the 02 sensors cut off as well. How bad will having no 02 sensors mess up the computer? Also, is there any way to keep it from upshifting while running in low gear?
Old 09-20-2012 | 02:22 PM
chris14e's Avatar
Check it out, on my 97 crown vic, I had 1 bad upstream o2s and the car didn't run so good. I replaced it and could not get the code to go away. I replaced both upstream sensors and runs great, no codes.
LastCallAgain
04-12-2012 12:38 AM
JonnyP71
10-23-2006 03:30 AM
ohno5o
09-14-2006 10:37 PM
ten8goa
08-01-2006 12:37 AM
jmikeray
04-26-2006 03:50 AM
