1999 automatic door locks stopped working
Old 07-08-2008 | 09:07 PM
KNEE's Avatar
Default 1999 automatic door locks stopped working
today my 1999 automatic locks stopped working . when I put the car in drive the locks do not automaticly lock anymore. I tried the sequence in the owners manual and the locks do there thing but still no go. any ideas? everything is working except the auto lock feature when put into drive. Thanks
Old 08-16-2008 | 12:10 PM
andry's Avatar
Default RE: 1999 automatic door locks stopped working
try to check central lock motor.
Old 08-16-2008 | 06:47 PM
way2old's Avatar
There are a lot of variables on your vehicle. Thr transmission range sensor can cause it if the PCM thinks the vehicle is not in gear. A door switch that is not operating properly may make the PCM think the door is not shut. Wiring can be a problem. The Lighting Control Module also can be at fault. A high end scan tool can read the parameters and isolate where the problem is. Good luck and keep us informed.
whiteface
01-13-2017 12:19 AM
Dmonte
10-23-2014 11:41 PM
mastermike
12-07-2012 05:49 AM
tonyna
06-24-2010 09:09 PM
dsd3535
09-13-2006 01:16 AM
