2000 oil pressure gauge question...
Old 01-24-2009 | 03:09 PM
ecobox's Avatar
Default 2000 oil pressure gauge question...
When I start my car, the gauge goes instantly to mid-range or so. Does anybody else's gauge behave like that? Or do you get a gradual rise from zero?
Old 01-24-2009 | 03:57 PM
Default RE: 2000 oil pressure gauge question...
Normal..
The oil pressure sender (switch) is nothing more than an 'open~closed' unit.. With normal oil pressure on start up the sender/switch will close and the gauge will quiclky jump to center gauge....
Old 01-24-2009 | 04:58 PM
ecobox's Avatar
Seems that would be the same as a useless idiot light. You have seen this on other Vics? To me, the only point to having a gauge is to be able to read the whole range. Other vehicles I've owned have had electric gauges with sending units that vary the reading, so if the On/Off switch analogy is true, this is a regression on the part of Ford or maybe just a cheap way to offer a gauge. Guess I will have to add a mechanical gauge.
Old 04-22-2013 | 07:21 PM
JAXGTO's Avatar
cheap open close switch if this bugs you should install a mechanical oil pressure guage
Fredo
04-22-2013 08:45 PM
77Bronco
05-09-2007 01:51 PM
Frito15
02-21-2007 04:48 PM
killgore101
11-03-2006 12:41 AM
ashclan
10-19-2005 05:40 AM
