2001 Crown Vic won't idle
This just started yesterday. Went out to car after work and started it. Engine wouldn't idle by itself. I can give it a little gas and it runs fine but dies when I let off. Did the same thing this morning. I kept it running for about a minute and it then would run on it's own. No spitting or sputtering, I can rev it up too, just won't idle. Any ideas? Thanks.
That is the part that needs replaced. Cleaning may not help the problem. I don't think it is too expensive. Motorcraft part number is CX-175 . It is about 60$ from Fordparts.com .
OK, thanks. For an update, it was warmer here yesterday when I got off work. About 80 degrees. I started it the first time and it died soon after. The second time I didn't have to give it any gas and it stayed running like normal. I have been thinking it mite be something temperature related. I've only owned the car since June so haven't had it in cold weather till now. I did have to replace the trans about a month ago. The fuel pump went out while it was at the shop. All that set me back $3650.00. They did tell me the engine was in great condition. I really like the car but don't want to be nickle and dimed to death. Thanks again for the info, you've been most helpful.
