2002 CVPI rear window defroster
Old 09-13-2009 | 08:37 PM
bthomas70's Avatar
Default 2002 CVPI rear window defroster
I have a 2002 CVPI and the rear window defroster don't work. I swapped the relay with others and checked the fuse and it was good, still no luck. When I push the button on the dash for the defroster to work nothing happens no light comes on. Does anyone have a clue what to look at next or what it could be?
Thanks, Brad
Old 09-14-2009 | 03:25 AM
securitymikey's Avatar
How about the switch is that good? I am guessing you checked the fuse too as there are probably other things tied into that curcuit so if that were the case other stuff wouldn't be working either.
Old 09-14-2009 | 03:38 AM
If you can get a voltmeter check to see of you got power going to the switch and the lines in the glass. It could be one of the two.
Old 09-14-2009 | 08:41 PM
bthomas70's Avatar
Thanks for your ideas I will look into checking out the switch itself it sounds like that could be the problem.
Thanks, Brad
Fordgirlescape
03-12-2013 09:41 PM
sunfish
10-28-2012 04:57 PM
singring
10-18-2008 11:37 AM
jdupont824
07-14-2008 05:57 PM
val608
10-23-2007 08:47 AM
