95 poor heater performance
Old 12-24-2007 | 07:03 PM
95vic's Avatar
Default 95 poor heater performance
Hello,
I am new here but really need some help. My 95 CV has never had a good hot heater since I bought her three years ago. I just replaced the thermostat, again, with an OEM FOMOCO 192 Degree thermosat. I also noticed there was not a lot of pressure at the recovery tank even after just turning the car off, so replaced the tank cap as well. It will not get above about a third of the way up in the normal range, and I don't know what the heck else to check. Am I missing the obvious? I do feel the fan clutch spins faster than it should for not running that warm, and it just seems that the thermostat will not close like it should.
Thanks
Old 12-25-2007 | 02:57 PM
btexpress's Avatar
Default RE: 95 poor heater performance
Are you concerned that the engine temp is too low, or more concerned about the heater?
If you are looking at a lack of heat inside the car, look at two things-make sure the heater core is not plugged by feeling both hoses to core, should both be hot. If not you might have a plugged heater core. The other item is the blend door motor which controls the temps from the heater/AC.
Old 01-16-2008 | 09:18 PM
bugman's Avatar
where is the blend door motor at. thanks James
Old 01-17-2008 | 10:09 AM
btexpress's Avatar
This motor is on top of the heater case, you have to pull the dash back to access it.
Old 01-17-2008 | 11:11 AM
87_Crown_Vic's Avatar
heater core replacement in these cars are a pain. i need to replace a heater core in one of my Crown Vics and need to pull the dash. i plan on cutting the heater core box and making a quick access panel. i have too many wires ran for lighting, and stereo stuff. you can probably guess that the car is sitting for the winter and i am driving a different car. when i get a heater core for it, i will get pictures of me pulling the dash apart and how i made a access panel.
cartoon2133
08-10-2008 10:30 AM
MTBoss
10-03-2007 04:54 PM
tesp
05-12-2007 11:01 PM
Fordman
08-01-2004 06:52 PM
