97 crown vic ac compressor clutch replacement
Old 06-12-2010 | 03:38 PM
dan rap's Avatar
Unhappy 97 crown vic ac compressor clutch replacement
my compressor clutch is noisy and loose, do i need to remove compressor from vehicle to replace it . . . if no, will i loose the charge in the system . . . thanks
Old 06-13-2010 | 08:18 PM
way2old's Avatar
You can change the clutch and coil without removing the compressor. You will not lose any refrigerant. All you need to do is get room to access tha clutch.
Old 06-14-2010 | 02:32 PM
dan rap's Avatar
Default To way2old
thanks for replying to 97 crn vic ac clutch replacement . . . now that i dont have to remove compressor and refrigerant, do i need any special tools and/or tricks . . . any help would be appreciated . . .
Old 06-14-2010 | 07:05 PM
way2old's Avatar
Socket and a snap ring plier. Socket to remove the little bolt in front (8 or 10 mm not sure). Then the snap ring to remove the clutch coil.
87 Royal Limey
03-13-2012 10:03 PM
Mith
05-27-2011 06:36 PM
spaztic_typer
03-19-2011 04:02 PM
87 Royal Limey
05-18-2009 03:13 PM
Madmax3040
07-10-2007 12:31 PM
