Crown Victoria Speed limiter
Old 05-13-2006 | 10:55 AM
taffy151's Avatar
Default Crown Victoria Speed limiter
I am in Doha Qatar and have a 2005 Crown Victoria 4.6L V8 and have found out that due to the fact that it is Middle east spec it has a Speed Limiter and ? Rev Limiter can anyone help with a suggestion as to the easiest and cheapest way to remove restrictions without copromising warranty many thanks Martin
Old 05-17-2006 | 01:43 AM
soutthpaw's Avatar
Default RE: Crown Victoria Speed limiter
What speed does it limit at???
Old 05-17-2006 | 01:05 PM
taffy151's Avatar
limits at 160kph 100 mph but i also feel acceleration is also limited
Old 05-18-2006 | 03:21 AM
soutthpaw's Avatar
It would be controlled by the PCM, you can probably change out the computer with one out of the Police Interceptor model which I am guessing limits at 140mph but never gone over 80mph so I cant tell you for sure. But it is definitely a computer controlled issue.
Old 05-24-2006 | 07:40 PM
flyboy's Avatar
In response to your rev limiter problem I have discovered how to eliminate the problem. I own a '04 Sport CV & after I replaced my stock intake system with a K&N cold air intake system I discovered I was limited to 118 mph by the limiter.I usualy got off of it around 100 because I heard they were limited at that speed. In the newer cars like yours & mine the only way is to utilize a "Superchip" micro tuner that eleminates the limiter, gives one the ability to adjust shift points etc. The older CV's had a chip you could change to enhance performance. That's the good news. The bad news is one of those tuners costs $425.25 with part # 1724. As you can see I've checked into it. I normally don't run above 85-90 here in Missouri since the Highway Patrol gets a little excited when you do. Hope this is some help.
Old 07-12-2006 | 02:40 AM
redshark's Avatar
yeah, I would assume that the only way to change that would be by reprogramming your computer with a chip, My CV actually tops out at 135mph.
Old 07-12-2006 | 02:43 AM
redshark's Avatar
Actually soory I missed the part about compromising the warranty. I would your dealer first, reprogramming the settings on your computer could void your warranty I would think.
jldude
01-02-2022 02:40 AM
jerome
03-17-2010 07:01 AM
zxtasy
07-11-2009 04:26 AM
jldude
02-20-2007 09:54 PM
MMatthews90
07-17-2006 11:10 PM
