ding ding ding
ding ding ding
1993 Crown Vic. Whenever I open the driver's door the alarm chime goes ding ding ding ding ........ Nothing else matters -- key in or out, engine running or not, sitting in the car or not, seat belt fastened or not, lights on or off.
All I really want to know is where to aim my 12-ga shotgun to disable the stupid chime. It's getting mighty old.
The ignition switch has been replaced -- no change.
Is there an alarm chime relay that might need replacing? Where is it located?
Thanks.
Thanks.
RE: ding ding ding
Could be the column mounted 'key in ignition' switch.. Even if the ignition were replaced (since a seperate part),, the grounding prong (completes the key in ignition circuit with key installed) could be grounding/shorted out causing the chime to run even though the keys are out of the ignition.. Easy way to test would be to pull the column covers and remove the ignition switch, then slide the plastic piece with the brass grounding leg off of the ignition switch bore.. Tape the removed piece and move it to the side out of the way and re-install the column/covers.. Or, you can cut the black wire leading to the grounding tab...
I'd look there first for a chime (ding) that is a constant...
RE: ding ding ding
ORIGINAL: Hayapower
RE: ding ding ding
Thanks, Hayapower and Dennis.
I had the "ignition switch" replaced at the Ford dealer because it was getting loose and sloppy. Might not be using the right term. It was the ignition lock cylinder. On some cars they are separate parts. On my '86 Volvo 240 the ignition switch is attached to the lock cylinder by 3 little screws. Not sure about the Crown Vic.
I didn't have it replaced because of the stupid ding ding ding. But I was hopeful ;-).
Anyway I'll pull the lock cylinder and see what I can see. Then I'll have AAA tow it to the dealer to fix my mistake. Or I could go back to the dealer and claim it was working perfectly before they messed it up. Nah, just kidding.
ExplorerOnKrome3152
03-11-2007 12:53 AM
