K&N Cold Air Intake Issue, 09' Interceptor
Old 09-23-2013 | 08:54 PM
Vinyard's Avatar
Default K&N Cold Air Intake Issue, 09' Interceptor
Hello, I own a 2009 Interceptor. Recently purchased a K&N Typhoon Series Cold Air Intake for my vehicle. Turns out the part is not compatible with the Interceptor computer. Seems to create problems for the mass airflow sensor. SCT Performance offers a computer programmer for the vehicle, whereby you can load various tunes onto your vehicles computer. I was told one of the tunes should enable the vehicle to accept the new air intake without issues. Can anybody shed some light on this issue? Any help would be greatly appreciated. Thanks.
Regards,
Vinyard
Old 09-24-2013 | 02:58 AM
GilbertF's Avatar
Thumbs up
Originally Posted by Vinyard
Hello, I own a 2009 Interceptor. Recently purchased a K&N Typhoon Series Cold Air Intake for my vehicle. Turns out the part is not compatible with the Interceptor computer. Seems to create problems for the mass airflow sensor. It seems SCT Performance offers a computer programmer for the vehicle, whereby you can load various tunes onto your vehicles computer. I was told one of the tunes should enable the vehicle to accept the new air intake without issues. Can anybody shed some light on this issue? Any help would be greatly appreciated. Thanks.
Regards,
Vinyard
Same issue is with my ride, searching for solution here.
Old 09-24-2013 | 04:59 PM
Vinyard's Avatar
SCT Performance - SCT SF3 Power Flash Ford Programmer Part Number: 3015
This is the flash tuner provided by SCT Performance. On their website they mention that with the tuner you can "Adjust for common performance bolt-ons such as Cold Air Kits, Exhaust Systems & Gears," but I've read through the user guide and have found no mention of any specific tune for the intake. I tried to contact SCT but that was of little help. The programmer costs around $400 so id rather be certain its going to work before I buy it.
Old 09-28-2013 | 01:16 AM
granpabobby's Avatar
I have a 2001 crown vic intercepter 4.6..what I did was add the K&N filter and remove the snorkel from the filter box then added a piece of exhaust tube to pick up outside air..works fine ..no problems from the computer
Old 09-28-2013 | 01:13 PM
Vinyard's Avatar
Wink
Thanks for the reply. What exactly is the snorkel? Is that the 4" piece of rubber tubing at the front of the existing air filter box?
Old 09-29-2013 | 06:05 PM
Correct..it is restrictive..from what ive seen the cold air kits pick up a lot of under hood air..I used truck exhaust pipe and a rubber plumbing coupler
Old 09-29-2013 | 09:50 PM
Vinyard's Avatar
Interesting. Thanks for the tip, I was under the assumption that the heat shield along with the rubber trim formed a nice seal with the hood. Definitely did not think it was getting too little cold air..
Old 09-30-2013 | 08:27 PM
Vinyard's Avatar
Will install an air duct on the intake side of the bumper. Maybe run some flexible 3" hose directly from the bumper to the intake. That should about do it eh? Granted there is enough space in there..
Old 11-04-2013 | 10:17 PM
thecoolblueduck's Avatar
Default Pictures?
have any pics to show the unimaginative?
Old 11-22-2013 | 10:12 PM
chrmaka's Avatar
You're going to need a tune. It's making you run VERY rich.
n4tit
07-22-2009 07:27 PM
tcaswell0282
01-16-2009 11:40 PM
GirlFokusZX3
10-14-2006 12:08 AM
treetopp87
08-19-2006 01:36 AM
proud2bfordpoor
04-01-2006 02:41 PM
