Marquis engine starts but stops immediately
Old 03-27-2007 | 11:10 PM
jinroh's Avatar
Default Marquis engine starts but stops immediately
It's a 96 Mercury Grand Marquis with 55k milage.
Today I started the engine, then the engine stops 2 seconds later. I tried again and hold the gas padel, the engine running. Then stops right after my foot leave the padel. After 30 minutes, I tried again, the engine starts without any problem. That's the 3rd time in last couple months.
The only thing I could think of is I changed original motorcraft spark plugs to bosch platinum 2+ ones 3 months ago.
Any suggestions are welcome.
Old 03-27-2007 | 11:40 PM
goinstrong's Avatar
Default RE: Marquis engine starts but stops immediately
Some spark plugs don't run well in older engines. If the factory didn't put them in there was usually a reason for that. It could be a lot of different ignition parts like the wires, cap, rotor, etc. which could also be affecting it though.
Old 03-31-2007 | 12:59 AM
way2old's Avatar
Checkthe idle speed control motor. Classic symptoms of it failing. Alse replce the plugs again with Motorcrft. Bosh will give you about 10 to 15k miles and fail.
Old 04-01-2007 | 09:01 PM
goinstrong's Avatar
Slight possibility of dirty fuel filter.
vmkrampitz
10-10-2021 11:45 PM
streetglide007
04-11-2010 01:23 PM
Philip
08-29-2007 11:19 AM
dsljay
08-08-2007 05:32 PM
jelmore
04-19-2007 03:05 AM
