OBD2 Connection Need Help
Old 09-07-2012 | 03:29 PM
chris14e's Avatar
Default OBD2 Connection Need Help
1997 Crown Vic. Several different scanner tools and the computer at the inspection station can not connect to the PCM. EEC-V DLC pin out is:
Pin 2, 0 VDC, Pin 4 is 1.0 ohms to gnd, pin 5 is 0.6 ohms to gnd, pin 7 is 12 VDC, pin 10 is 5 VDC, pin 13 is 0.53 VDC, and pin 16 is 12 VDC.
All grounds at 104 pin PCM connector are good.
Any ideas?
Old 09-07-2012 | 10:11 PM
This is something you can try.
If you disconnect as many of the sensors you can find ,then see if the scan tool can communicate with the PCM. IF it does, start reconnecting them one at a time and when you lose communication with the PCM that is the sensor with the problem. If a sensor is shorted it will prevent the modules from communicating with each other and the PCM.
If you want to , try disconnecting the DPFE and CKP sensors first. They are the most common causes for this problem.
Once you get it to communicate you may get some codes. Must be careful, because you can get some wild codes. The scan tool must be CAN (Controller Area Network) capable.
Your voltage readings appear to be in line at least for the pins that matter.
Old 09-08-2012 | 02:39 PM
chris14e's Avatar
Hi Hanky, I will try this. You see I just bought the car, and of coarse there were jumper wires and black tape every where. Thanks, I will start looking at the sensors.
Old 09-09-2012 | 03:48 PM
chris14e's Avatar
Hey Hanky,
ok i disconnected all sensors 1 at a time from engine, trans, and exhaust, still can't connect, any other ideas, pcm?
Old 09-10-2012 | 03:56 AM
A lot of guys are reluctant to replace a PCM because of the cost. If all the checks check out OK then it's time to bite the bullet.
Old 09-13-2012 | 11:08 PM
chris14e's Avatar
Well the new PCM will be here tomarrow, maybe I will work on it Sat or Sun. I'let you know. Thanks any way it was a good try.
Old 09-20-2012 | 02:17 PM
chris14e's Avatar
New PCM no more problems!
Old 09-20-2012 | 02:31 PM
Glad you were able to solve your vehicle's problem.
cyberrkatz
02-20-2014 12:25 PM
Porsche650
03-19-2013 12:19 AM
Beakstert
01-27-2013 12:25 PM
f250jonm
12-27-2008 11:58 AM
gdjordahl
09-20-2007 11:59 PM
Quick Reply: OBD2 Connection Need Help
