Power Steering Fluid
Just changed out the power steering pump and need to put power steering fluid in. the problem is, I cannot find what fluid I should put in. it is a 1995 Ford Crown Victoria.
What kind or brand of power steering fluid do I put back in?
thank you!
thank you!
The fluids listed are hydraulic fluids that happen to be used in transmissions and power steering units. If you want a red colored power steering fluid use one of the listed ATF fluids and if you want a clear fluid use the higher priced "Power Steering" fluid.
