Problems with Fueling.
Old 02-11-2008 | 09:01 PM
Markey44's Avatar
Default Problems with Fueling.
I'm having difficulties when fueling my 2004 Crown Victoria. It has been an progressive problem and it is now to the point that it will bearly take fuel except as a very slow rate. I put it on a computer program and got the following the code " P 0442". Do not know if this code has anything to do with the fueling problems or if it is another independent problem.
Any suggestions would be appreciated!!! Thanks.
Old 02-12-2008 | 09:44 AM
87_Crown_Vic's Avatar
Default RE: Problems with Fueling.
dont stick the gas pump neck so far into the filler neck of the car. you can try turning the pump handle upside down when fueling also. only times gas pumps do that to me are at specific stations. usually it is the pump itself and not the car.
Old 03-20-2010 | 09:45 AM
fourbuds's Avatar
Check the vent line to evaporation canister. Mine had spider cobwebs in it. Blew it out with compressed air. Problem solved.
Old 03-20-2010 | 01:56 PM
digital_diversion's Avatar
" P0442" is Evaporative emission control system leak detected...usually a fuel cap or vent line issue...
Check rubber seal on gas cap for wear and check vent line for blockage as recommended by fourbuds
Old 02-07-2011 | 01:29 PM
Johnnny45's Avatar
Default 4 Fuel pumps in two months
I got codes that were related to fuel pump, I changed the pump with a new ford replacement. Two weeks later the pump failed ford put a new pump in. two weeksafter that ford chance the the fuel pump module and replaced the pump again, you guessed it the pump quit again.Also it's slow taking gas when I refuel . Anyone have this problem or any ideas?
Old 02-07-2011 | 09:03 PM
Douglas_48's Avatar
If your seals are if'y that could throw codes luxury cars portland lexus
Old 02-09-2011 | 12:16 PM
Johnnny45's Avatar
Default No codes now just burnt out pump number four
I have find out what is burning out the fuel pumps? to much labor and expense to keep replaceing pumps every two weeks, somthing has to be causing this.
Old 02-11-2011 | 03:36 PM
Johnnny45's Avatar
Default Will find out soon
Well the car is being shipped up from fl to ny. I will let you know what we find. I am sure this will happen to someone else.
Old 02-12-2011 | 10:21 AM
Johnnny45's Avatar
Default Fuel Pump
This car is a P71 car with a fuel pump module in the trunk . I am wondering if it uses a differant pump then the normal one. Maybe that's the reason the pumps keep burning out.
LiveTao
11-13-2011 02:28 AM
