Pump In Fuel Tank Runs Constantly Even With Key Off
The battery in my wifes car went dead. Upon installing a new battery, I heard a hum as soon as I placed the battery cables onto the battery terminal.
Inspecting the vehicle, I found that the hum originated at the gas fill door. Opening the filler door and removing the gas cap, it was obvious that the pump was running within the gas tank.
The key is in the OFF position but the pump within the gas tank runs as long as the battery is connected. I assume that it should only run when the ignition key is in the ON position.
What would cause this problem?
RE: Pump In Fuel Tank Runs Constantly Even With Key Off
Your prompt reply is most appreciated Hayapower.
My wife's Crown Victoria is a 1989 4dr model, 302 V8, PS, PB, AC, loaded, and in mint condition. I just checked at the gas fill cap..... that pump is still running.
If you could tell me what that relay looks like and where it might be located, that would be a great help.
If I remember correctly, they were mounted on the left/drivers side of the engine bay in a panelabove the inner fender.. 'Tap' the relayand see if the pump shuts off..
Hayapower...... The new Maxx 65S battery that I installed was discharged due to that pump running. I checked it (battery)previously with a hydrometerbefore installing and all cells registered 1.275/1.300 specific gravity. However, after charging for an hourwith a commercial charger (I'm a marine mechanic), the battery is charged BUT the specific gravity does not register at all with the hydrometer.... I mean it registers absolutely nothing! I checked the hydrometer on my truck battery and it registers normally. I'm at a complete loss to understand this.
The relays.... I found a few of them (four)secured in a shieldedcover type arrangement where you said to look for them (inside top portion of left front fender). They're unmarked so I have no idea which one would be the fuel pump relay. I had to unbolt (2 screws)the relay bracket assembly in order to gain access to them. I "tapped" on all of them, then went back to the fuel tank access pipe to listen. The pump was now silent. Apparently, as you suggested, the relay was sticking.
The four relays are different colors..... Black, Green, Beige, and Blue.
I'll go to the Advance Auto store in the morning to see if they have a service manual for this 1989 FordCrown Victoria which might shed some light onwhich relay I need to replace.Any furtheradvicewould be appreciated.
mama2clean
05-17-2010 08:09 PM
TerryP
10-04-2008 10:42 PM
cjc4x4
06-09-2006 12:24 AM
1989, 99, constant, constantly, continuously, contour, explorer, f250, ford, fuel, maxx65s, pump, running, runs, thunderbird
