Quick Crown Vic question
Old 03-15-2010 | 02:00 PM
jgaddy's Avatar
Default Quick Crown Vic question
New to the forums here so a little info first. I have a 91 Crown Vic I got from my dad. The car has maybe 35000 miles on it, 302, and basically loaded. He let it sit for a couple years before he decided he couldnt drive anymore and gave it to me. So far I have replaced the dr side window motor but still need to do the other three, needs the A/C compressor replaced, and the odometer and trip odo quit working right before he parked it. Its showing 29995 miles right now. After some reading on here I found the thread about the gears in the instrument cluster that I can replace to get these back working. THX for that.
Now the question, it needs the intermittent wiper/blinker/high beam controller, Do I have to take the steering wheel off to do this and if I do, how do I disarm the airbag?
I am going to do the speedo repair and intermittent wiper/blinker/high beam controller at the same time and if all goes as planned I will take pictures and do a little write up.
Greg G
Old 03-15-2010 | 07:57 PM
way2old's Avatar
The multi function switch unbolts from the side. Remove the steering column trim and you will see 2 little torx head screws that hold it in place. When you remove speedo, be sure to unkook the gear selector string or you will have to buy another.
Old 03-16-2010 | 11:04 AM
jgaddy's Avatar
OK thanks for the information on the selector spring. Its the little things like that that will save money and time. I am going to be doing this in the next couple of weeks.
Greg G
michaelm811
06-17-2011 12:06 PM
Pony88
12-26-2006 05:37 PM
dropshadow
11-11-2006 03:39 AM
lhgdale
08-24-2006 08:17 PM
penny
02-08-2005 12:30 AM
