speedometer problems
Hello I have a 1996 Crown Victoria P71 and the instrument cluster works great except the speedometer and odometer stopped working all the other gauges work..... I scanned it the code was P0500 vehicle speed sensor (A) malfunction.....does that mean i need a new cluster?? I replaced the speed sensor on the transmission and that didn't help any info would be great thanks
[align=left] [/align]
RE: speedometer problems
Click here Is this the one you replaced? There are 2 on the transmission. One is the output shaft speed sensor and it is located farther to the front. If you replaced the correct one, look at the wiring and remove the sensor and be sure the gear on the output shaft is not loose or broken.
If you replaced the rear sensor, that is the one that controlds the speedometer and odometer. The Output Shaft sensor is about 8 inches directly ahead and slightly above the VSS. I don't think that will be the problem tho. You might want to check the associated wiring to the sensor.
You might tryremoving the wires and using heat shrink tubing around the wires to keep them separated. This will rule out that wiring section as a problem. The problem with that is you will probably have to lay on your back to do it. Good luck. Be careful not to break the locks on the connector that holds the wires in.
eloycastro22
09-04-2012 12:48 AM
