Temperature Sensor
Old 01-24-2014 | 07:13 PM
timbogates's Avatar
Default Temperature Sensor
I am getting a code for P0125. It appears that I may have a stuck open thermostat. The vehicle warms up in 4-5 minutes (starting to warm up) in 25 degree weather. The electronic display never exceeds 3 bars but normally it is 4 bars on the digital display. I am not sure if I need the thermostat or possible new coolant sensor. I am not sure if this problem is related or not so I will describe.
In hot weather after driving for 30 minutes or longer in just hot weather above 90F. If I stop for 5-10 minutes and crank it up it will immediately go to a low idle to the point that it will almost die out.
Appreciate all your thoughts.
Old 01-24-2014 | 07:41 PM
For the cost of the thermostat and it's replacement there should be no question or concern especially if the vehicle is more than 3 years old. By that time it's time to look into coolant replacement also, to help lessen the possibility of internal corrosion.
The thermostat rating should be in the area of 195 degrees F. Once that is done it will eliminate that possible cause from the concerns.
Airman89
08-06-2015 02:53 PM
animal1408
10-02-2011 10:30 AM
Rattler
04-13-2007 10:29 AM
newyorker
01-12-2007 03:50 PM
johnsonsnb
12-06-2006 02:07 AM
