traction control
Old 12-30-2007 | 12:51 PM
caddyking19's Avatar
Default traction control
hi im new to this site but i have a question i need some help...i have a 92 crown vic and when ever i floor it the car spins tire very little then like abs kicks in or something is this some sort of traction control an can i turn it off because i hate it..also if i hold the brake a little bit it will roast the tires but the second i let off the brake the tracion thing kicks in i need helppppp!!!
Old 01-15-2008 | 09:30 PM
87_Crown_Vic's Avatar
Default RE: traction control
if you look at the door sticker on the car, it will give a description of stuff about the car. look at the sticker and see what it says under AX. here is a rearend write up of different rear gear ratios and whether or not it is a trac-lok(posi) or an open rearend. the year you have wouldnt have traction control in it.
Open rear/Trac-Lok/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / ------- / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / ------- / 3.63
J / ------- / 3.85
Old 01-15-2008 | 09:59 PM
ok i looked and i have 3.08 gears but when i put the cold air intake in it there was a thing on the anti lock unit that said traction assist on it..i looked in a service manual an it say that traction is active until 34mph and it deactivated when the brake is applied..if i try to burnout it wont if i apply alittle brake just enough to make the brake light go on it roasts the tires..theres no switch to turn it off either..i need to by pass this....
Old 01-15-2008 | 10:07 PM
you would have to mess with the ABS system in order to bypass it if it has it.
Old 01-15-2008 | 10:08 PM
yeaa thats wat i was thinking but i cant find awiring diagram on the abs system..im thinking i can disconect the trac assist an stil have a working abs system
Old 01-15-2008 | 10:37 PM
thats why i like my older CV. regular old power brakes and no ABS. more stuff there is, the more issues i have with cars.
s007059
11-24-2011 08:16 AM
rcook
02-11-2008 11:44 PM
s007059
06-02-2006 12:16 AM
s007059
06-01-2006 10:16 PM
s007059
06-01-2006 10:12 PM
Quick Reply: traction control
