'02 E150 4.6 surge/misfire
Hello, I am working on the above vehicle, and I seem to be at a dead end. It seems to surge or buck when easily accelerating while driving. If you floor it, it runs good. Also runs good at idle. Scanned for codes- none stored. I replaced the spark plugs at my friend's request, with no change. With all the reading I've done about the EGR pressure sensor, I put one of those on as well. I used Motorcraft plugs and a Ford sensor. I took apart the throttle body and all that to check the EGR ports, which were clean. My next guess would be a fuel injection flush, which i am going to do tomorrow. After doing a little more reading today, I am going to check and see what the TPS data says while driving. At this point, I'm out of ideas, and have put a little thought into the idea that it may be the transmission. The fluid isn't burnt and it is full.
Any help for a GM guy here trying to help a friend out?
Thanks
Thanks
jfh123
04-25-2014 11:36 PM
