02 E250 Rear Door latch cable diagram
Check my signature.
I randomly picked V8-4.6L. So next time you ask a question don't forget this, even though even size might not matter in your case, look at the pic above I had to select the engine size to be able to continue.
Rear Door handle Removal
1) Remove the door trim panel and watershield.
2) Disengage the cable keepers by pinching the keeper ends together and sliding each keeper toward the outside of the door.
3) Disconnect the cables from the door handle.
4) Drill out the rivets, and remove the door handle.
Installation
1) Follow the removal procedure in reverse order.
Don't forget 5 pdf attached below.
Installation
