1991 e150 5.0 no crank.
Old 12-27-2023 | 08:30 PM
jasonfountain's Avatar
Originally Posted by Scheerhorn
So I ended up trying to crank it while cycling through the different gears and that worked! Than I turned it off and it cranked normally again! Happy day indeed.
Now my question is, what do you think caused the problem and what should I worry about fixing? It’s an old van that I just got and needs a lot of upgrades.
I think it is probably your neutral safety switch aka transmission range sensor. It’s like a $60 part and takes like 15 mins to swap out
  #22
Old 12-28-2023 | 02:23 PM
Scheerhorn's Avatar
If everything is working right now , it will be difficult to find something wrong when there is nothing wrong.
I would suggest, if you feel the need to, copy the suggested procedure in the earlier post and save it. As you know if you are ready for it to act up , it won't, that is the way it goes lol.
That is definitely my experience as well!
The only problem now is an exhaust leak in the engine bay and a rhythmic metal shaving sound directly tied to the speed of the wheels. The exhaust leak I’m less worried about short term. What do you think the sound coming from the rear wheels might be?
1995 Ford E150 1/2 ton Van (8 Cylinders H 5.8L FI 351 CID)
  #23
Old 12-28-2023 | 02:25 PM
Scheerhorn's Avatar
thanks for the tip! It stopped cranking again and it took a simple move of the shifter to neautral back to park and it started right up. Also the shifter has always has trouble going into the gear that it shows on the dash. With all this info, does that still sound like the safety switch?
also there’s a metal shaving sound coming from one of the back wheels that speeds up as I speed up. Maybe it’s a depleted brake drum pad? Any ideas? Thanks so much!
  #24
Old 12-28-2023 | 03:59 PM
I believe there is more going on here than we realize.
If it was only repositioning the switch assy ,that is one thing, but because the shift position indicator is also lying ,tells me there is more going on here.
If you can , look at the bottom of the shift tube assy close to the firewall. Check if there aren't loose parts there when you move the shift lever.
Before suggesting any addl things, let's see what, if anything, you find, thanks.
Solar07
08-27-2023 07:36 PM
Fordtwo
04-23-2020 05:36 AM
Kevin262731
03-20-2018 01:49 PM
Kennysauto
07-02-2012 02:02 PM
Davetheslave
02-07-2007 07:09 PM
Quick Reply: 1991 e150 5.0 no crank.
