1991 e250 wiring diagram??
Old 02-16-2013 | 11:13 PM
anthonypoletto's Avatar
Default 1991 e250 wiring diagram??
Anyone out there have a wiring diagram for this era e-series?? I'm having regulator problems!!
Thanks
Old 02-17-2013 | 10:59 AM
Hi Tony,
What kind of "Regulator" problem are you having, may be able to help ?
Old 02-22-2013 | 04:28 PM
Alternator is new, battery is good, but not charging. Wiring btwn alt. and reg. has obviously been messed with, so I need to know the correct wiring up to that point at least. Help?? Thanks!!
Old 02-22-2013 | 07:08 PM
Does your van have an ammeter or just an idiot lite for the charging system.
The hot lead on the alt goes to the "A" terminal on the regulator plug.
The "F" terminal on the alt goes to the F terminal on the regulator plug.
If the vehicle has an ammeter, then the wire from the ign switch goes to the "S" terminal of the regulator plug.
The "I" terminal of the regulator plug is not used with an ammeter system.
If this info is not sufficient you need to provide more info as to just what you have and what the charging system is or is not doing.
Eldridge174
02-06-2014 07:47 AM
Kenster
02-27-2013 11:58 PM
harley3348
06-03-2012 07:02 PM
REDNECKRUTH
09-02-2009 10:51 PM
caliba
05-03-2005 03:54 PM
